El Burro 8 HP bearing needed
I have an El Burro set up with a clutch and an 8 HP engine. The tires are bolt on type, the previous owner made an adapter to get away from the all in one tires. The end of the front axle has bearing cups. One of the bearings is starting to break up. Can anyone give me a tip on where to buy a new one? Thanks, Paul
joshua. c.
most bearings have a model number printed on them on the front or back. clean yours up and try and find it. if you do find it look it up on ebay for a replacement.
I guess I could try to pull it out. It has a sturdy rubber seal, a couple off flat washers and countless tiny roller bearings. It is not clear that the bearing could be removed as separate from the outer cap. Thanks for the reply.
