El Tigre kick stand and front forks wanted
I am looking for a kick stand and possibly front spring shock forks for the El Tigre I just picked up. Also, a rubber brake pedal cover if you have one.
Thanks!
capguncowboy
The brake pedal covers are impossible to find, but you can get a close match from an automotive store.
Your forks weren't bent enough that they should be an issue. Try straightening them out. The lowers should slide out fairly easily, at the very most, you'll need to replace the lowers. The springs are definitely going to be okay
I haven't looked it over real well yet, do the lowers screw out once the front wheel and fender are removed?
