Ell burro
The valve stems are on the inside of the hub leaning against the axle . Not easy to put air in the tires , and even harder to keep the air in most of them . You will probably be making axles and looking for 21-12-8 tires with a 4 lug 4 inch bolt pattern . Been there done that . If you go looking for replacements , remember they are directional .
Thanks for your help.
