B BrianWI New Member May 25, 2007 #1 May 25, 2007 #1 Looking for a new 4-5hp 4 stroke for a mini bike.
B BrianWI New Member May 30, 2007 #3 May 30, 2007 #3 Happen to have a used H70 flywheel? Do you know if the geared (electric start) and non-geared are interchangeable in a pull start application?
joshhoward New Member May 31, 2007 #4 May 31, 2007 #4 Hey Brian It doesnt matter geared or not for the pull start. I have some extra H50-60 flywheels. Ill check to see if they fit on my H70. Josh
B BrianWI New Member May 31, 2007 #5 May 31, 2007 #5 Thanks. Someone really did a sloppy job on this motor
RuppParts New Member Jun 2, 2007 #6 Jun 2, 2007 #6 electronic and point ignition flywheels are different taper. h50-h70 flywheels will interchange if both point ig or both electronic ig
