Fastest Doodlebug!
On my way to work thinking about minibikes (it's all I think about!) wondering who has the fastest db?
I have a db30 old style that does between 50-55.
I'd like to see what everyone else is running.
buckeye
Isiah, check out the Michigan Mini Bikes on Facebook.
Those guys are building some baaaaaddddd bikes up there in the frozen tundra.
vwfan79
I have one that was running in the mid 60s @ 10.8 seconds in the 1/8 last year
That's cool vwfan. I've never been time trapped but have made several passes down a drag strip.
It was an old school flag drop race at atomic blast. Its a rat rod event
buckeye
Pics or it didn't happen.:laugh:
That's flying. What is your engine and gearing?
View attachment 69582 this is the first run before i tuned the carb up HATERS
View attachment 69582 this is the first run before i tuned the carb up HATERS i dont know how to change headings but myproject log is "under construction"
212 clone HEMI
Dynocam f-275
head shaved minor port and polish .010 gasket
custom intake PZ26 slide rejetted
Doverpower flywheel 6 degree advance key
arc rod
ss valves
spring upgrade
briggs fuel pump
#19
Mines a motovox and I'm at 55 on level ground but ive clocked 65 on a downhill run My gearing is 36tooth sprocket, tav2 , ported head, billet flywheel ,adjustable carb ,KN air filter ,velocity stack ,header, 26 lb springs ,I believe im at 32 degrees of timing oh and I had no tail wind
