Hiya guys,
I am a treasure trove of questions
As I mentioned in the previous thread, my son and I built a modified predator engine in anticipation of putting it on the Azusa.
Engine worked GREAT, started easily with one pull, and throttle worked flawlessly. Started it up and let it run at least 5 or six times. The mods at this time were:
Arc Stnd Rod
Arc Billet FLywheel (gap at .055 or so per Arc recs)
14cc head (ported and polished)
Mod2 Cam
Stainless steel valves (standard rockers)
Honda 0.625 Carb (NR Racing)
Header
Autolite AR3910x sparky
I ordered and installed at 1.3 stamped rocker from Arc along with the appropriate guide plate...I CHANGED NOTHING ELSE
Set valve lash as noted above (currently pretty close to 0 degrees cold at TDC)
NOW,
Engine is very difficult to start (in fact, I only got it to start once after MANY pulls and sore hand) Revved once and died.
It "pops" every third or fourth pull, I smell gasoline (smells rich), and sometimes hear a pop and see exhaust puffing out of Carbeurator.
I pulled the valve cover, rechecked lash. Rechecked coil gap. There is a visible spark from the spark plug. I smell gas so am doubtful it is a fuel problem.
I am stumped. and VERY frustrated. About to pull the head....just to DO something. Not really sure what I am looking for.
The only thing that has changed is the rocker. Unless this is a "red herring" as they say.
Help!
Thanks
Brian
Arc Stnd Rod
Mod2 Cam
Header
NOW,
Help!
Thanks
Brian
