Funderbird Go-Kart (Model #704014) by Bird Engineering
Overview:
Type: Go-Kart
Model: # 704014
Mfr: Bird Engineering
Specifications:
Performance:
* (a) Maximum Speed -- 30 mph
* (b) Climbing Ability -- 30º
* (c) Minimum Turning Radius -- 128"
Engine:
* (a) Maximum Horsepower -- 4 at 3600 RPM
* (b) Displacement -- 10.5 cu. inch
* (c) Type -- 4 cycle, single cylinder
* (d) American-made Tecumseh with 10,000 authorized servicing dealers stocking parts and performing warranty.
Drive:
* Symmetric torque-sensing torque converter that automatically selects correct drive ratio for any terrain. Ratio 3:2:1 to 17% overdrive, smooth and instantaneous.
Frame:
* Precision jig welded heavy duty cold drawn tubing reinforced in all critical areas.
Wheels and Tires:
* (a) Front -- 13 -- 5:00 x 6 Goodyear tubeless terra tires mounted on deep dished 6" steel wheels.
* (b) Rear -- 16 -- 6:50 x 8 Goodyear tubeless terra tires mounted on deep dished 8" steel wheels.
* (c) Prelube double sealed ball bearing in both front and rear wheels
* (d) Dual sprockets on rear assembly for easy tire rotation.
Body:
* One piece metal flake, all weather, automotive style, fiberglass body -- never needs painting.
Seat:
* Bucket-type foam padded, high quality vinyl covered, bottom and back.
Brakes:
* Proven foot operated dual rear wheel cam action.
Steering:
* Automotive style easy grip, 12" steering wheel and foot operated throttle.
Dimensions:
* (a) Overall Length -- 61"
* (b) Overall Width -- 38"
* (c) Overall Height -- 24"
* (d) Wheel Base -- 48"
* (e) Minimum Ground Clearance -- 3 1/2""
Bird Engineering
P.O. Box J
Fremont, Nebraska 68025
Overview:
Type: Go-Kart
Model: # 704014
Specifications:
Performance:
Engine:
Drive:
Frame:
Wheels and Tires:
Body:
Seat:
Brakes:
Steering:
Dimensions:
Bird Engineering
P.O. Box J
