Hello all. I was hoping someone may be knowledgeable about the Foremost Golden Pinto minibikes. Just picked up this fixer upper. Attached is a pic of my rear axle mount. It is just inside the rear loop. Everything looks factory and untouched. Problem is every other Golden Pinto I see has rear axle mounts that extend to the rear of the frame loop, not inside the frame loop like mine. I know both Bird and Arco built these but can anybody explain this? Thank you.
