GoPower 72? tooth sprocket and brake assembly
Daniel Coop
Looking for 6" GoPower wheel 72? tooth sprocket and brake assembly! If I can't find them the wheels are available.
There's some type2 Go Powers with bendix brake and 72 tooth on eBay $200obo
Daniel Coop
Thanks, but those are my wheels... I'd probably keep them if I can find a decent sprocket and brake. Would trade straight up for some 6" wheels for my Trailhorse
your wheels you posted in the for sale section are "series II" go powers so the sprocket is not hard to find :thumbsup: All you need is a 3.25" bolt circle sprocket NOT the nearly unobtainable 3 stud go power sprocket. There is a regular seller on ebay that sells NOS bendix sprockets usually with a low starting bid in both 60 and 72 tooth count, and a 5" Bendix brake can be bought direct from allied leisure that is workable with the right spacer. Or you could go with probably just about any Universal brake/sprocket setup that has the 3.25 pattern in it.
Good luck
Daniel Coop
Thanks Marcus and everyone else who gave input. I'm learning more every day. This forum is a wealth of knowledge!
