I need to replace wheel and fork bearings and bushings and need some direction in identifying them. Anybody point me to a parts list for these?
On the jackshaft I was going to machine off the end that the old torque converter sheave is mounted on and replace it with a sprocket so I can reuse the jackshaft. If I use a 6.5 Predator and a Comet 30 TC, will I have to ditch the 22" tires to keep from burning out belts? I've read that the largest tire I should go is 18" to keep from buring out the belts.With a 48 tooth axle sprocket, 10 tooth on the J/s output side and 10 tooth on the torque converter side what should I use on the J/S input?
Lastly I need new front tire shocks-anybody have a good replacement for them? Thanks
