Just installed the flywheel and rockers. The stock windmill vs the PVL:
The flywheel definitely needed lapping. It rocked on the taper. Two rounds of valve grind compound did the job well. Afterward, I sharpied up the crank and spun the flywheel. The contact was perfect. Gap set at 0.040" Torque the nut to 54 ft-lb and install cover.
After I put the flywheel on, I wanted to give it a pull to make sure I didn't screw something up. One pull, two pull, three pull and the air filter shot across the room. Surprising the plastic intake didn't explode. Put the filter back on, put it on stands, safety squints, hand ready on plug cap, and gave it a quick forth pull. Fired right up and purred like a kitten. Guess I just have to get used to that.:shrug:
I chucked the rocker pivot nuts in my lathe and rounded and polished the ball ends with some 320 grit and scotch brite.
The rockers, NRR left, OEM right:
The NRR rockers are indeed stock ratio (1:1). Mr. Mike Rometer and Tristan Decatur agree:
I did recommend these rockers in another thread but I can't remember which one. I want to take it back.:doah:
