Only 118cc, expensive (Honda), and the Rammer type has a weird 15mm PTO/crankshaft drilled and tapped for a 12mm bolt (wouldn't leave much "meat"), length not specified. If you already have the engine, you may need to replace the crankshaft with a different type to be able to fit a clutch.
