OK, the new three magnet and two 1 wire coils showed up today. I took the engine apart and installed the new parts and test ran the engine.
As stated above, the coils are grounded to the engine block. You must put one leg of your AC output to the engine block to get maximum voltage.
Unloaded,the AC output was over 30 volts! It of course this turned out to be just a potential not capable of doing any work ( load).
That being said just the AC outputs are much lower than the four wire systems. On 1 coil running at 2500 RPM I'm getting right at 6 VAC. With two coils tired together it only rises to 10 VAC. With loos through the voltage rectifier/ regulator I'm only getting a very strong 8.5VDC. The LED is bright but not at maximum Lux.
for those of you running a 6 volt light(s) your good to go. Lots of amps (current) to play with.
I tried ever combo nation I could think of with no increased output results.
What I will try next week is to de-solder the "shorter" wire to the iron from of the coil and hook a 2ND wire to it and see what if any change can be made?
If this solves the low voltage problem,and works like my other bike, then all is golden.
One of the links on the FOUR wire coils show clearly the one end of the coil is NOT grounded to the iron core. This may be the answer to the question as to why the voltage drop?
