small open ended wrenches work pretty good.. Maybe a flaft screwdriver... If ya stack everything on top of a couple like 1/4 inch open ended wrenches, you cab usually slide the stuff right together.. :thumbsup:
Yep, like restorekid said just use a flat screwdriver. carefully slide the retainer to the side toward the hole, and it pops right off. You can use the screw diver to put it back on also. good luck
