Heald Hauler $750
Need to clear some room, too many projects, not enough room. First pic is how I got it, the second is how it is now.
THE GOOD
Front forks were disassembled, cleaned and greased. New ozite bushings and bolt in steering stem. New bearings in front wheel.
Rear axle was disassembled and cleaned, greased with Bentonite and new bearings.
Briggs 11hp, gas tank replaced with external tank, new coil, plug and voltage regulator . Carb removed and cleaned.
Transmission disassembled and cleaned, fixed issues from previous owner, missing shims, roll pin and c-clips. New bearings and oil seal on input shaft.
Clutch was disassembled cleaned and lubed, new belt
Emergency brake has new cable and band.
Frame has been lengthened 6", because I'm a fat old guy.
THE BAD
Brakes haven't been touched, have a new master cylinder, but calipers need rebuilt and new lines run.
You can check out the build here
https://www.oldminibikes.com/forum/index.php...
Located near Cincinnati
