Not much to update, been working on it a little bit here and there. The seat is done and looks great! I tried to bleed the brakes last week, but when I filled the master cylinder with fluid it didn't flow. At all. I guess I should have torn it apart and checked first, it moved back and forth smoothly so I assumed it was OK, but as it turns out, it wasn't. The seals were both shot and the bore is a little iffy. I was able to get a rebuild kit for it, so we will see if it's save-able or not.
The biggest thing that has helped me with this project (and saving my back) was the purchase of a full sized motorcycle lift table. It has side extensions that fit the Hauler well, and is pneumatically operated so no more heavy lifting and bending over:thumbsup:
