Having some issues getting my axle shafts alignment so the wheel is center. The wheel wants to move right and left on the shaft. The drum break bolts to the frame but with it bolted there is no way for me to add the inner nut to set the play. I have to keep shimming the axle shaft and this is causing all kinds of issues. What am I missing here? When I got the bike the brake drum was attached by a solid rod connection (not to the frame). I have done away with that in replacement for a foot cable brake but that's not my issue it is like something is missing that I can adjust the wheel with or I am doing it wrong.
I have the brake drum assembly, 4 nuts and 2 washers. Am I missing something here?
Thanks all
Thanks all
