I recently built a clone with all the goodies , cam, springs,arc rod,flat top piston, anyway I ran the motor for like 20mins then I notice it was leaking
oil out the side cover gasket. I removed motor from the bike and broke the engine down , I wanted to check torque on rod & switch cam & springs. I change the cam, checked the torque on the rod then put 26# spings in. everything went normal until I tighten side cover, then motor won't spin freely, I loosen it & it spins, tighten cover & motor locks tight. I don't know what to do. HELP
