Once warm then you adjust running or not. did you check the slide open height? did you set fuel mix adjuster? Once warm it should try to start. you can raise slide more but it may rev high and turn out mix adj. What values are your pilot jet and main jet?
-Also clarification on what my problem is at this moment, is when I start the engine on my bike the back wheel spins obviously at which of a high rpm so basically it doesn't idle properly.
-Also the engine stalls when the choke/enrichment is off. Even when I let the engine heat up for good amounts of time.
