Help my Alexander Reynolds
Thanks to the help of some people on this website have identified my mini bike as a Alexander Reynolds I was wondering how much it would cost for a new motor and a front and back wheels with rims and where to get them and what type of motor to get please help ps it has a separate gas tank like a motorcycle that i would like to use and it has a friction brake like you push down on a separate pedal and it pushes against the tire my budget is 400$
There are several places you can get parts. eBay. Member: Hentcom
There is a few supply houses that also sell parts. What is your location? Maybe one is close to you.
DaddyJohn
Skip the new motor; the proper model is likely a Tecumseh HS series. Luckily, you live in the snow belt, and these can be had pretty cheaply off of old snow blowers. Front wheel can be made up from a $15 harbor freight 6” implement wheel and a set of proper bearings, though you may have to cut the central hub down a little for fork clearance. Don’t use the tire that comes with BTW, it’s junk.
