After a good soak with penetrating oil, screw a longer bolt with a washer on it into the end of the crank, pick the engine up by the converter clutch and have a friend wack the bolt with a BFH. The washer is to keep the engine from hitting the floor when the converter comes loose.
And make sure, you wear gloves and safety glasses!
