I have a new to me 71 0r 72 Speedway Blue Angel. It has an HS40-55395C Serial Number1295B.
I was checking the point gap and I see there is no condenser. All of the wires seem to have a home and I have spark at the plug.
Is there suppose to be a condenser in this ignition circuit?
The engine fires but the most it will run is run 3 or 4 seconds. I put a new china carb on it ...new spark plug gaped the points. I have no idea when it last ran it has good compression. I thought it might be a timing problem so that's where I'm at. Thanks
I probably should have posted this on the Tecumseh thread. I'm a newbee.
