like ole4 said earlier, we need pictures of your parts. also on a different note with 275 lift and 1.2 ratio that will put you at 330 lift so you will need about a 36 pound spring. also sometimes how aggressive the cam can dictate less or more valve spring rate. 36 will get you in the pall park.
