Bone stock Hemi, Haven't cracked the case open as I'm leaving the governor installed for now. I am however switching valve springs for durability. I have a degree wheel installed for checking timing because I also swapped out the flywheel for a Kohler with a lighting coil. So I was turning the motor over by hand, watching the rockers. After the intake closes, and the piston starts moving up the bore on the compression stroke, I noticed the exhaust rocker move. I double checked over & over and it definitely moves. I didn't put an indicator on it, but it's probably .020 or better. It starts to open at 140 degrees BTDC and closes again at about 40 degrees BTDC. Looking at pics of camshafts I see some weights and springs. Is it designed to bleed some compression off for ease of starting? Please forgive the newbie. I've built engines for my drag car, but this small stuff is new to me. Always something to be learned.
Thanks for your time.
