Saturday I was out on the Hilltopper and the right hand jackshaft bearing came out of its holder. The "C" clip groove had worn away. A large groove had been worn in the shaft also a lesser groove where the other bearing sits.
I welded it up, ground it in, new bearings and clips .... ground the brake puck too ... good as used!
Then I check the jackshaft on the new Hilltopper ... notice the sprocket side bearing has been welded on place?!
The sprocket is worn as well ...
Guess I know what I'm doing tonight!
Hey Yoop, might want to check yours ...
