Can someone confirm if this is correct on my SB. The throttle doesn't want to close if the move the lever that the cable pulls at all. If you move the lever far enough to close the carb the spring on the arm is totally free and not returning the arm any longer. In the pic you can see that the lever is rotated so far that the spring is free on the right side by maybe a 1/4''. Its got me baffled. It is as if it is missing a spring but its all there. It will crank and run but it doesn't want to return to idle unless you pus the lever down with your finger. You can see how far the cable stop is and that is where it frees up the linkage until it will go back to idle.
Spring not making contact.
If you move it just until the slack is gone out of the spring then it is opening the carb.
Am I missing something or is something missing? I cant figure it out. It acts like it needs a return spring but I thought that was the purpose of the spring on the throttle linkage in the pictures....
Help......
Doug
Help......
Doug
