i wonder if its a rupp factory mod, or a rupp "spec".
but you have a side popper, did rupp make a side popper equipped mini?
:laugh: I doubt it, That was Tecumseh's "EZEE-start" for the small frame H, you can even see it in part numbers. The cam is 31317 (no compression release) on the '69 and in 1970 the part number is 33149 "compression release". Of course the block numbers changed to and the parts description will note cast iron (part number 30644a) and the '70 33077......this is comparing a 1969 Rupp scrambler engine h35-45210G and a 1970 Rupp Scambler engine H35-45304H
The 1969 side exhaust I have was not a mini bike engine, it has all the makings except the throttle assy has the bolt adjuster in lieu of the cable collet and torsion spring so it was a fixed throttle application originally (an Rupp didnt use any side exhaust engines).
I haven't run any H35's without comp release on them...yet. I did a couple of the pre 70 HS40's in the past by pulling the flyweight pins and its pretty noticable when starting, I am working on a couple of H35 right now and worked the bump off the 33149 cams (one is a 1971 H35 the other is for a custom later model 3.5 sidepopper that uses the larger HS sized crank and rod and big exhaust valve) but I am only to assembled longblock stage on the 71 and havent started paintwork or anything yet....
I left the govener gear out....OOPS :wink:
I'd be interested to see if the drilled hole was standard in the '60's I don't have any engine's earlier than the 2 1969's right now though. I only have a shroud and numbers From a 1962 H35, but the part numbers wont pull up anything online anymore and I sold off all my old parts books and manuals. You really gotta look for the hole when you pull an old engine apart, the carbon usually just camouflages it and you wont really notice it until you start cleaning.
