hi all
I m doing my first build on a ct200u with a honda clone. So far I removed governer. Swapped in a new 3/4 crank.Put arc billet rod. Pvl flywheel with 4 degree key 18 lb valve springs, mikuni 22 mm carb and a torque conveter, as well as a cs grind cheater cam. I also have a 60 tooth rear and a ten tooth front with 420 chain
My question is before I put in the torque converter i was spinning over 6000 rpms and with the tav im only spinning 4600. Does this sound right? Or did I do something wrong I'm not catching. Currently bike is topping out at 38. I was hoping to get mid 40's.
This is the first time i ever built and engine and im hooked.. i was happy it started and ran after i cracked it open. Any help to get me to the mid 40's would be great
