The Oregon carbs run good.. They are the same idea as the originals, just look different..
The problem with the Oregon carbs, is not only price.. BUT they a lot of the time are not even complete.. Theres no throttle plate and shit.. They expect you to build YOUR OWN carb from their carb, PLUS your old one.. :glare:
SO if you do not already have a carb, the right carb, and your parts aren't broken... You have an 80 dollar brand new pile of useless.. :mellow:
When buying carbs the biggest thing to look for is the carb size, then next thing is how all of the parts work, choke arms will work on one motor, but hit the exaust on another... One throttle plate works right for an H35 or HS motor.. but put it on an H50 and it won't hook to your throttle parts.. :mellow:
Your best bet is buy one thats been custom built to fit the engine your need, and tested and tuned by someone who knows what they are doing.. :thumbsup:
http://www.oldminibikes.com/forum/m...-hs40-h35-h50-fully-adjustable-carb-35-a.html
Also, someone had mentioned the fuel inlet and said you want a strait in, which is wrong, all HS engines were 90 degree elbows... On a motor with attached fuel tank, the line runs behind the blower housing, on a motor with no tank, it runs upwards towards the tank on the bike..
