Hi guys- new to the forum and really appreciate all of the deep knowledge here! I am messing around with an HS50 that i am prepping for a Ruttman Spyder. I removed the governor and installed a Dosens 631918 carb that I learned about from some other threads.
Engine starts fine and I got the idle smoothness optimized with the screw about 1.25 turns out (more than I expected). Then I revved it up to adjust the main jet. It is happiest at about 1.75 turns out, but it heats the exhaust cherry red and shoots a nice blue flame while revving. If I turn the key even a 1/4 turn in either direction is drops the rpm significantly.
So far I have checked and re-gapped the solid state to flywheel magnets to .0125 as specified and gapped the plug correctly. Both intake and exhaust lash is on the high end at .11 (.06 nominal spec). No cracks in the head, and new gaskets on the intake and exhaust so no air leaks. Also removed the ring gear from flywheel.
Anything we I need to check? Is the flaming typical when the engine is revving not under load? I'm pulling my hair out on this one...
