HS50 magneto problems
well i have this generator powered by a hs50 tecumseh nd first i checked for spark no spark spark plug was good so i checked the points
the points were shot i bought a new condenser/points i set the point to .020 apart i got the timing right on nd i try 2 to start it nd no spark not even a little shock what else can be the problem i bought a new spark plug but nothing?
can be the problem?:cursing:
still cant get it to work i had spark today cause i switched out the coil the big black peice with the two wires and got spark the timing is right and then when crancking it it started then it lost spark i checked it again and still no spark i took it apart and still nothing
