points motors were time with about 15 degrees advance,
I've never put my degree wheel on a Tecumseh, but did wonder about this. If the stroke is (Post 1982 H35, and early HS 40 and 50) 1.938. and there are 360 degrees in a circle, one degree of rotation should be .00538 inches. Since timing is set at .035 BTDC, (.035/.00538) doesn't that put timing at about 6.5 degrees BTDC?
The early H35 with 1.844" of stroke would equate to each degree representing .00512" per degree. Timing is set @.065, which equates to 12.6 degrees BTDC.
Just using the math, not a degree wheel, because the last thing I want to do is mess with a degree wheel, an ohm meter, a depth gauge fixture a screwdriver, and a feeler gauge all at the same time. :laugh:
I'll also add that of the many engines I've timed, (I don't mess with OHV, or solid state Tecumsehs) none of them would run worth a damn if the timing was out by more than a few thousandths. In some cases with well used engines, I couldn't even achieve the timing without bringing the points down to as close as .014 @TDC, or slotting the stator plate. This is so common, I don't even bother with setting .020 at TDC anymore. Had some conversations with ATK Rider, and he said the same thing.
The above leads me to suspect Tec added that .020 spec @TDC just to give technicians a starting point. I've also noted that lightly used engines had ring end gaps well in excess of the book stated .007-.017, but I digress.
The question about when Tec started changing their internal configurations "seems" to have occurred in 1983, when the stroke of the smaller engines were all changed to 1.938, and they pretty much melded the H35 into an HS40. But I do recall seeing both large and small exhaust valve heads on H series pre-1982 engines. All of those changes might well have occurred as the company was looking at the OHV market, and their eventual demise.
My experiences is limited to about ten or 15 engines for vintage mini bikes, but it's just my guess. And looking at the specs in the L Head manual dtd. 1998, it seems obvious an attempt was made to standardize for parts replacement over any EPA concerns. Hell, just look at the HP ratings, and you know that they slapped a sticker with whatever they want. My H35's have always had noticeably more power than my HS40's.
