A few months ago, I was quite involved with my HS50 restoration and making good progress. A rarity in my neck of the woods, I've had to bring in a couple of bits and pieces from the USA.
One key part that I imported, was a crankshaft. My original had a 1" PTO, and a stripped thread on the flywheel side.
I imported a really nice HSSK50 crankshaft, 3/4" PTO, just what I was after. I didn't realise that the flywheel taper would be slightly different, though. The part number for this crankshaft is #37245.
The problem I now face is that I need the correct flywheel to continue. Which flywheel am I looking for? My engine had the late 70s (presumably) aluminium flywheel, which I noticed was heavier than the earlier aluminium flywheels I have handy. None of which suit the taper of my new crankshaft.
Any guidance on flywheel part numbers etc would be really helpful. I'll take any measurements needed to make that happen. I look forward to giving this Tec' a new lease on life!
Pictured below is the "mess" - as purchased. The original color appears to be white.
This is the flywheel that it had paired with its original crankshaft. The taper on this is different to the one on the crankshaft I'm trying to use.
Not the best picture, but this is the replacement crank I'm using.
Thanks!
Thanks!
