IS THIS SERIAL NUMBER 1970 OR 1980? SERIAL- 0243B
colt 1911 Active Member Jan 14, 2021 #1 Jan 14, 2021 #1 IS THIS SERIAL NUMBER 1970 OR 1980? SERIAL- 0243B
mustangfrank Well-Known Member Jan 14, 2021 #2 Jan 14, 2021 #2 Can't tell by numbers...metal tag on shroud or stamped on shroud/recoil housing top?
colt 1911 Active Member Jan 14, 2021 #3 Jan 14, 2021 #3 mustangfrank said: Can't tell by numbers...metal tag on shroud or stamped on shroud/recoil housing top? Click to expand... top of housing
mustangfrank Well-Known Member Jan 14, 2021 #4 Jan 14, 2021 #4 Wait a moment, trick question, HS50 didn't come out until 1972 I believe. Have to be a 1980 or possibly a 1990
colt 1911 Active Member Jan 14, 2021 #5 Jan 14, 2021 #5 mustangfrank said: Wait a moment, trick question, HS50 didn't come out until 1972 I believe. Have to be a 1980 or possibly a 1990 Click to expand... if you are correct about 1972 then it is 1980 because it has points
mustangfrank Well-Known Member Jan 14, 2021 #6 Jan 14, 2021 #6 Yep, that seals it, could be slightly off on 1972 (by months or a year) but they did not make them in 1970.
Rooster63 Active Member Jan 25, 2021 #7 Jan 25, 2021 #7 August 30, 1980. It was a Saturday. Everyone was Drunk. 2nd Shift, too. Yikes.
