The placement of a spacer between the right and left bearings of a wheel hub is an important detail that a lot of people don't pay much attention to; much less take the time and effort to install properly. If you want your wheel bearings to last; a spacer is an absolute necessity. If the spacer is too long your bearing won't fully seat into the ends of the hub. If it's too short it will serve no purpose at all and you may as well not go through the trouble of installing one. In this tutorial I will describe a relatively easy procedure that will allow you to properly install a spacer with an accuracy that is within one thousandth of an inch. Overkill you say? Perhaps. But when you're in your garage with a big hammer trying to remove your old chewed up bearings old OGY will be out riding his minibike. Let's begin: Picture #1 below shows the hub, spacer, and bearings that need to be installed. Start by inserting (preferably using a hydraulic press) a bearing into one end of your hub like in pic #2. Next measure the dimension between the inner face of the external retaining ring and the inner face of the bearing as shown in pic #3. Then find a piece of scrap (I used aluminum) that is the same thickness as the dimension you just measured and make a washer pic #4 with a center hole that is the same diameter as the axle you will be using. After that you will need to find a piece of steel rod that is the same diameter as your axle and cut it so that it is just a little longer than the distance from one end of your hub to the other. See pic #5. To be continued.
