Lot of miscellaneous intake manifolds... fit Tilly carbs. Most are flathead Briggs, but I think may be one or two that are or Animal or Clone engines. Don't know for sure. $40 for the lot.
Mystery aluminum blocks... appear to be some kind of manifold, but I have been unable to track them down. Gold is brand new with hardware. Red is used. $20 for gold one, $10 for red.
Air cleaner adapters/velocity stacks... (three in pic, all used)... $10 each.
Two new in package air horns/air filter adapters: $20 each.
New in package GEM Products intake manifold $20
Electric starter nut for flywheel: $10
ARC crank gear... new in package... I've been told this can be used to adapt a flathead Briggs crank into an Animal/OHV block, but I'm not specifically knowledgeable to this. Have two available, one pictured is new in bag, other is also new but out of package. $10 each.
Desktop Dyno for flathead Briggs. 3.5 inch floppy disk (retro!) $20
Recoil starters: brand new both, one for Tecumseh, other is for Briggs Animal: $15 each
