I am re-gearing a jackshaft that is bolted to a honda clone on a baja heat/warrior. The clutch has a 10 tooth sprocket, that has a chain that connects it to a 20 tooth sprocket. The 20 tooth is on a shaft that spins a 10 tooth sprocket that drives the 50 tooth sprocket bolted to the rear wheel of the bike.
I am planning on changing the 10 tooth sprocket that drives the rear wheel to a 15 to gain some more speed. Would that work? or could anyone tell me what the best gearing setup would be? :shrug:
Or, has anybody ever re-geared the jackshaft on a baja heat/warrior?
