Leaking oil
My 5hp flathead has been leaking oil for quite some time. I checked the crankcase gasket and that seems fine, and the flywheel and that area is fine, what are some areas that the engine leaks? Thanks for the help.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Does it leak with the engine/bike sitting level? If not, it might be the oil filler cap (if at the bottom of the crankcase cover). I had a similar problem with a Tecumseh and traced it to the filler. I went by the hardware store and picked up a fiber gasket and that seemed to fix it. Another common problem is the oil drain--snug it a bit tighter than you think you need to--had that issue on another engine.
The crankcase breather located below the intake/ exhaust ports has been the most prominent area to leak for used engines I've acquired. The crankcase gasket would follow next.
bandit 40
If this has a governor on it check the lever under the exhaust towards the bottom they are also know to leak there on a worn engine.
