Great looking bike, woild you happen to know where I can get a front rim 8 inch for a manco ?
thanks
Newman
I have a TBird I'm modifying. I needed a front tire also. I was in Tractor Supply and got an 8" wheel barrow tire with a knobby pattern. It was only $16. It has a grey rim but that can be painted easily. Sure it isn't meant for high speed travel but it should be good for a minibike. I had to change the wheel bearings. It came with cheapy bearings with a 3/4" ID. I put in regular flanged minibike bearings with the 5/8" ID.
I also added a band brake to the clutch. WOW, it will lock the rear tire with the slightest touch. I have to get used to that...
I left the scrub brake on for emergency's in case the chain comes off
I'm putting on a different front fork set up, removing the gas tank bracket as I'll use a Briggs with a tank under the carb. I want to put a different seat on it and relocated the shocks to the back of the seat rather than the center of the seat. I'll also use a much better pivot design on the front edge. I don't like all the side to side play in the original seat set up, it sways around way to much. It will be more like the Cat MX Duster seat and shock design that I had recently. I may have to relocate the rear axle further back to prevent all the wheelies... I had a 5hp Briggs on it for a couple days and it was hard to control with the front end in the air all the time... A 4hp Tecumseh was better but would still wheelie when you didn't want it to. A 3hp Briggs does fine as it won't wheelie with it.
I got some universal front and rear chrome fenders that I'll need to fab brackets for. I made my own full length clutch and chain cover.
Plus I'll do some more stuff to make it my own bike. This is a an ongoing project. I change things, ride it a bit, change things, rinse and repeat. Once I get it changed up I'll give it a paint job this winter. I'll keep the frame red but will go with a white engine, white wheels, black handle bars, black seat and black clutch/chain cover. It will be red, white, black and chrome.
Pics will be posted when I take more. It is pretty ratty looking right now...
Danford1
Here are a couple pics of the way I got it from the swap meet. It was a roller with a wasted front tire.
