if it is an original light and it is dim, the first thing you want to do is make sure all of your connections are good. No loose or frayed wires flopping around in the wind or where they are fastened to spade, or round connectors or spliced together. Take off the connections and clean the connection and the place where they are connected to with a wire brush or fine grit sandpaper, steel wool, something along those lines. If there is rust/corrosion in any bulb socket, it either has to be cleaned out of there, or the socket has to be replaced. Electricity has to be able to flow like a river. Bad connections are like a dam. The the electricity has to go around or through these bad areas, and voltage is lost.
