The clutch cover on my clutch is loose, and I'm wondering what can be done to fix the problem. It's a Bonham climbaway clutch on a Tote Gote 670, the cover sits between the engine and the actual clutch. The cover has a spot for the key stamped into it, and is also supposed to have a smaller tab facing inward, which seems to have broke off on mine at some point. The key seems to fit fine into the groove in the clutch cover, but it still is loose and has play in it. I think it's because the small tab is missing. What I can't figure out is how that small tab of metal is supposed to keep the clutch cover in place? how does the clutch cover stay clamped down? Do I need to have the small 1\8 inch of metal tacked back on to secure it?
Any suggestions to secure this clutch cover down?
Here is a climbaway clutch cover (not mine). You can see the keyway and the very small protruding tab beneath it.
Thank you
Thank you
