I got this chassis a ways back in a package deal with some other stuff, and finally found a way to motivate it. The PO had previously mounted a Predator 212 (poorly) at some point, so the motor plate was pretty hacked-up, and the steering bearings were trashed. He had also cut off the rear grab rail, the foot peg mounts had been torn off, and the fenders were garbage. Otherwise, it was looking reasonably good...
Cut to several months later, and my brother-in-law dropped a free snow blower off at my door, thinking I might like to fix it for use. After seeing so many cool vintage minis with Tecumseh engines, I decided to take the H40 off the blower and see how it looked on the Doodlebug. Answer is, "kinda" like a real vintage mini!
Anyway, a new clutch, new Tecumseh mini bike throttle linkage, new eBay carb, a set of vintage Yamaha passenger footpegs and mounts welded on, custom motor plate, custom number plate, custom clutch guard, custom chain guard, and custom air cleaner mount (with eBay pod filter), and she was ready to rock! I did take the blower housing off, welded the primer bulb hole shut, painted it, and added the decals (the Ruttman decal is more of an homage than anything, not going to fool anyone, lol... ). I had to bend the choke lever to the other side, then fold it back at an angle to get the swing right on it. I topped it off with an old climate control knob off a 60's Chrysler or something. The custom dash panel mounts the original Indak key switch from the snow blower, and an old Monte Carlo badge I had in the tool box. Add a rabbit's foot keychain, dice valve stem caps, and a motorcycle reflector in the rear (for safety, lol), and that's pretty much it!
