making a non adjustable carb adjustable
I started taking a non adjustable tec carb apart to rob something from it and it appears that the body itself is the same as an adjustable :shrug: anyone swap the parts over and use one, be nice to have a fresh body to work with and this ones clean/new.
:eek:hmy:I would imagine it would have to be machined for the low speed circuit?
Ahhh, I see know, I had popped the cap off and saw the standard head and thought it was just put there to keep people from adjusting it but after unscrewing it I see its a fixed jet and there is not enough depth for a needle :doah:
The high speed appears that I can install the needle assy on though. I dont know what this carb was intended for, will they not idle down? My buddy said he could not get it to run after a rebuild but when I popped the bowl off I found he stuck the black o-ring up into the main circuit, the needle seat was in cockeyed and the welch plug fell out of the overflow :laugh: Hes not allowed to play mechanic anymore :confused:
heres the stuff that came off it (not the adjustable on the right though)
