Center the engine first, but don’t bolt it down too tight. Then slide the clutch on and see which way it lines up with the rear sprocket. I think you will find that the 11 or 12 tooth clutch sprocket will be on the inside. Once the clutch is installed, make the final adjustment on the engine and tighten it down.
