They are direct bolt on to many minis , lol . May require drilling the axle holes open if you go larger than 12mm and the trees are set for 10mm but can be drilled out to 5/8" .Very easy to make a front fender mount too !
First post, hello and welcome! It's very similar to the Motovox MBX11 fork, so it should be an easy fit; I think it would be pretty much a bolt-on; may need to play with wheel spacer lengths; may need to tweak the Motovox fender brackets. One way to find out!
Ain't that the way it goes? (finding a better deal after buying) $79.99 with FREE shipping buying from MM via Amazon. Click the yellow "See All Buying Options" button.
The $13 shipping charge from MM was mentioned in post #4; try to keep up.
The ones listed on Amazon are sold by and shipped by Mega Moto, so that is MM's inventory. With that being the situation, I would assume that when it's sold out on Amazon, it will be out of inventory at MM, unless they allotted only a percentage of their inventory to be sold on Amazon. I think that when it's sold out on Amazon, it will also be sold out on the MM site.
I wasn't trying to be cruel, thus the . It's easy to post something thinking it's humorous, then see it later and realize it may not be perceived that way by others, as was the case here. Unfortunately, with this new format, we only get 10 minutes to edit a post, which isn't enough time, IMO. If my comment caused any offense, I apologize.
Mine showed up today as well. It's basically a bolt-on for my Coleman CT200U. I am using a DB30 front wheel and will need to mess around with the spacers as the ones it came with won't line everything up. It's better quality than I expected it to be as well.
I'm planning on running maybe some CRF50 risers with Pro-Taper bars.
Couple of bad pics since I wasn't going to move the car to get better ones.
I got these forks on a monster moto mb80 and a db30s (older style frame). The forks make the ride much more comfortable. I'm tempted to get some for an AZUSA frame I got.
