Hey everyone, new to the forum and I could use some help. I have a 196cc with the following done to it:
- Remove governor
- New flywheel
- Billet connecting Rod
- Stock piston head
- 1.3 ratio rockers
- 22lb valve springs
- mod2 camshaft
- exhaust header
- and breather on my mikuni vm-22 (Genuine Mikuni)
I have tried 2 other Chinese carbs with no luck and now finally bit the bullet and bought the real vm-22 mikuni carb. I have tried the stock 100 main and 30 pilot jet, 12.5 pilot and 130 main and finally I tried the 17.5 pilot and 140 main with no luck at all. If I slowly accelerate it will bog a little from 0 - 1/4 throttle and then it’ll pick up but if you give it a normal rate of twist on the throttle she boggs right out and turns off. Not sure what else to do I’ve tried moving the needle as well still no luck. Any tips or advice is much appreciated!
- Rob
- Remove governor
- New flywheel
- Stock piston head
- 1.3 ratio rockers
- mod2 camshaft
- exhaust header
- Rob
