minibike brake light/turn indicator LED kit for sale anywhere?
I have a modified late 1940's-early 50's Hiawatha minibike. I'm going to swap the engine with one I just built that has a generator flywheel. 12 Volts at 5 amps. I'd like to put on a set of mini LED turn indicators and brake light.
I will not be running a booster battery as there is no room for even the smallest sealed lead/acid type.
Hooking up the wires/switches is not an issue.
Is there a complete kit that will have the blinker module built in or will I have to mount one in line with the turn indicators?
My mini only has a rear brake drum and the hand brake does not have a switch / cable built in.
I would like to keep the lights as small as possible.
Lights are not required by any law,however I am on paved streets for most of my riding.
The minibike is not stable enough for one handed steering / hand signals due to it's very small wheels and size.
Thanks for any info.
Hey Rob...do you have, and would you sell the original engine ?
I think Rick Chatten [MENTION=18319]chatten63[/MENTION] is looking for one ?
