Got a little done in the past few days. I decided on an engine. It's a 5hp Briggs. After putting one on the Boonie and the black clunker, I decided to put one on this one too. This one had a bad crank and rod. I had another one with a broken mounting ear on the block, so I robbed the crank and rod from it. I bought a new piston, rings, piston pin, intake valve and gasket set.
I removed all the casting slag from the rod and polished the beam with Mothers.
It's all back together and all seems well. I also rebuilt the carb. I polished the intake runner of the carb with Mothers and cleaned the ridges and slag from the ports. I still have to make an exhaust for it.
I bought a comet 20 series drive clutch and painted it with BBQ Black. The driven clutch is a Comet 21 D-7. It's a 7 1/4 size. with the small rear sprocket and 10" wheels, I figured I might need a little help taking off. This should do the trick. :thumbsup:.
The lef spring on the left will be the rear seat spring instead of shocks.
The seat brackets are painted.
I also built some more bearing blocks for the jackshaft. The same style I made for the Boonie. The deal with the two little extra holes is they can be bolted to different length bottom blocks for different width bikes. Or if I weld them together, I can thread these and use them to mount chain/belt guards.
At the beginning of the build I said it would have a reverse upside down springer. I was just trash talking.....
BUT, after trying on the original forks and another set,I decided I would go ahead and build it. I'm going to modify the original forks, using flat bar,bronze bushed bolt holes, hardened shoulder bolts,and my own design.:grind::hack::weld::hammer::smile: The fun is just beginning.:biggrin:
