Made a little more progress. But first I wanted to back up and show the bearing blocks and mounts in the first pic. I salvaged a couple of pieces of leaf spring from a pony cart. The short one will go on the bottom and the longer one on top. I'm going to add a medium length one between them which will be slotted for adjustment to get the ride I want.They will be bolted on with the bottom steering head nut. I will drill beside it on either side and add pins or bolts to keep it centered with the triple tree. I made some rockers from 5/16X1" mild steel bar. I plunge drilled pilot holes on the mill for accuracy, then drilled on the drill press to 5/8 and added flanged bronze bushings. Made some pivot axles from 1/2" precision ground steel rod,threaded the ends with fine threads. Made stuts from 5/16X1" steel bar. The struts will be drilled with a series of holes over the whole length of the struts, to lighten and make them a little more presentable.The upper and lower ends will also be rounded off. The cross bar on the top end of the struts will be drilled and tapped on either side of the spring for a flat bar clamp to clamp the spring to the strut. The forks actually function pretty smoothly, but I'm sure it will take some tuning to get it right. I would like to echo Yellowhands saying that if you plan to build a front end, do a lot of research on rake and trail, spring weight, load, rate, etc. If you'r over 40 years old, and have been chopping and modifying everything you've ever owned since you were 10 and/or have studied a little Geometry, Physics, engineering, hacking, hewing, beating and thumping,cutting and welding......go for it. Jeri's Springers site has a simplified explanation of rake and trail. It is very basic but a good place to start. Just remember he is most likely using a 21" wheel, and everything must be scaled down in proportion to a mini.:hack::grind::hammer::weld: :smile:
