Minibike/trail bike identification
Thanks, but how do I know what year it is exactly, I’m trying to rebuild it. Thanks for the help.
If the info on the linked page is correct, it should be a 1978. That page shows the first frame number for '78 being 052318 and yours is 052812. As I said, @Gatecrasher is familiar with the MT1/KV75, my mentioning him will alert him the next time he's on here. If you're impatient, you could send him a private message (use "Start conversation") and he will receive an email if he has that notification enabled.
Gatecrasher
You can easily tell it is a 1976-80 KV75 frame without looking at any numbers. It is not a 1971-75 MT1 frame.
The difference between the two generations were subtle but a main difference was the way the seat mounts to the frame. A MT1 seat bolts to the frame while a KV75 seat has spring-loaded latches.
If you look closely you can see this frame has the two posts for the KV75 seat latches rather than bolt holes so it is a KV75 frame.
